TwinTurbo.NET: Nissan 300ZX forum - Re: Throttle body adjustment ?
wild_maxx
on May 14, 2015 at 12:21 PM
posted by ttz'in (norcal)
on May 14, 2015 at 11:13 AM
Can you get the idle down to 650 RPM with the AAC disconnected? What's your TPS voltage set to and did you confirm the hard idle switch is on at closed throttle?
Did a boost leak pressure test and even sent Fog Machine
ZTicket(Dallas)
09:53:26 05/14/15
When idle, your RPM's should increase when you turn
FrozTTy
10:28:02 05/14/15
As I've stated above, boost leak pressure test. IACV is new
ZTicket(Dallas)
10:39:33 05/14/15
ttz'in (norcal)
11:13:32 05/14/15
Re: Throttle body adjustment ? -
wild_maxx
12:21:43 05/14/15
IIRC I could barely get to 650 before adjustment
ZTicket(Dallas)
12:33:13 05/14/15
THIS makes the most sense. Especially since
ZTicket(Dallas)
12:38:46 05/14/15
Same issue, upper plenum was replaced and idle
ttz'in (norcal)
17:06:00 05/15/15
